k5roc
Rob O
Apr 17, 2008
39
Worcestershire
www.k5roc.co.uk
Hi
anyone come across this fault with the radio on their SEAT?
Its an ALTEA with the built in radio cd system
MW reception has gone completely - jsut fuzz. FM is fine although a little weak sometimes
Ive had the radio out and checked the Aerial and there are no loose wires so it must be in the radio unit?
any ideas?
There are 2 different radio types used in the Altea, both are made by Blaupunkt (BNO) but the question is which you got there exactly. Even though you don't see a loose wire doesn't mean it's not faulty, have you checked the radio for fault codes as well as the measuring blocks and checked the reception that way?
