android auto/speedometer google maps on headunit
PeterPetrus
14
Hi all .When I'm using android auto/google maps on the phone the speedometer is there but when using on the headunit is not there. From settings the speedometer is on .Any idea why is not displayed ??? . Is about the resolution of the headunit display? Maybe is the headunit software ? . It is a mib2 with SW MU version 0252 ,car is 65 plate.Thank you.
PeterPetrus
14
Hi. Thank you for the link .I already checked this link. The problem is like now I choose one destiantion on maps/android auto and the speedometer is there. If I'm doing the same thing but connected to headunit the speedometer is not there.
PeterPetrus
14
It is the same ....speedometer on the phone with android auto but not on headunit with android auto.
CW92
103
27
Not sure if this is any help but from what I can see it appears a bit hit and miss and I'm not sure if they have seperate settings for Smartphone only vs via Android Auto.
You need to turn on the speedometer in the maps app settings, not in Android Auto which was counter intuitive to where I thought it was. In our version of Android, in maps, go to settings, Navigation Settings, and near the bottom in driving options you can turn the speedometer on or off.
Sometimes it only works when I’m using a route, not sure why it doesn’t show all the time…
CW92
103
27
I thought that may be the case but thought would double check just in case.
Good luck and will be interesting to see if there is a hidden setting or something similar.
