gazzrazz
Hello, I was wondering if any1 can help. I have a 2004 leon cupra with a really annoying squeek when going over bumps. Its sounds like its the drivers side. has any1 else had this or can any1 advise what it maye be.
also while im posting, any other members from the wirral area?
cheers
FRONT BUSHINGS? Does it go away when its raining, and then start again when dry, if so its prob ur bushings, i had to replace them every 20k ish
no it seems to be from the rear and never goes away unfortunately. well unless i turn the radio up!
It might be where the back of the rear seat locks on, i wrapped a bit of tape around the loop that the seat locks on to and it seemed to do the trick!
cheers nickb34 worked a treat! would never have found that!
Squeaking!!!
I also have an annoying squeak.. in fact its really bizarre. Tends to happen at low speeds and around 2-2500rpm and it's almost like a digital watch alarm..very feint..going off either in the air vents or behind the dash! Had the car for a year now but Seat are crap whenever i've taken it to them... any ideas? :think:
