If i am right it keeps your turbo spinning inbetween gear changesand on launches so there is like it says no lagg from the turbo. ussally used on race/ rally cars where turbos are only used for a short time then changed. aparently it eats through ure turbo and it wont last very long with it.
I have had some thing smuliar done when had my stage 2 at jabba, at high revs when u dip the clutch for a gear change the engine jumps 500 revs before entering the next gear there for keeping the turbo spinning i asume = less lagg.
some one else mite have a better opion though. :p
say if i wanted to get anti lag, does anyone have a rough idea who could do this or a rough idea on the price more to the point, i know its not ment for road use
I didnt think anti-lag could be used on these engines??
iirc the closest is a WOT box with launch control, pretty much does the same thing as antilag, you still get the pops and bangs
Plus.......
The small turbos (K03S KO4 etc) aren't laggy anyway - so what's the point...........? Lag is the delay in a turbo reacting once it's spooled, a lot of people confuse it with spool time.
