Gone to fit my front ARB today and it would seem I am missing a couple of key parts on the underneath of my car.
Accordin to my diagram it is the bolt and bracket which sits on the next hole down from the rear subframe bolt.
So one end of my ARB fits at the front end of the subframe then the arm swings back and goes up over the rear end of the subframe across to the other.
I have the bushes for the part that connects the ARB to the rear of the subframe I just don't have the bracket or bolts on my car.
Any help anyone?
Mine is only a 98 1.4 so is probably not meant to have any ARB parts already on.
Hi - are you talking about a Neuspeed rear bar? From your description, I think this is the bit that you have to make as the kit is designed for a slightly different car. You need to make up some angle brackets to get it to fit. If you can wait until this evening I can probably take some piccies of how Badger Bill fitted mine.
Yep, I've got a front one as well. I'll see if I can get any pics this evening - but might be tricky without any ramps _ I'll see what I can do.
Here's the bit I mean:
If that makes better sense?
its a pissy little clip & m8 bolt that retains the bar & bush to the subframe
My eibach kit cam with the clips as I had a 1.4 ibiza at the time so wasnt an issue
its a maindealer parts job...
Would you know what they are called exactly so I can explain to a parts department, because knowing me I will just get it wrong?
Or do you possibly have the parts number?
On GSF I find this?
42274A ANTIROLL BAR LINK-FR IBIZA ALL MODELS 94> FROM 6K-TR-040001>
is that the one?
I'd like to thank GSF for ****** me about today.
Phoned them, didnt have a clue.
E-mailed them the above photo, yeh we have one of them
Went to fetch it today, no mate its a dealer only part
FFS, are you retarded, waste of a drive!
Can anyone help me on the part number?
Tracking now done,
couple of pics:
You can just make the clip out I had to buy! Otherwise it would of been on sooner!
Don't tend to get understeer seems more over but it does like to glide on the road but I haven't stopped smiling.
Well worth the pennies :)
