Did you change the tweeters?
No. Too much hassle as the door cards have to come out. I just used speaker and wiring adaptors then snipped wire 2 on the adaptor to disable the OEM tweeter. This leaves the OEM wiring intact so you can easily revert back to stock.
If you dont snip the wire then wont the oem tweeter still work aswell as the new aftermarket speaker you put in?
I put new door speakers in my ibiza which had seperate tweeters and id heard when you plug aftermarket speakers in they wont work but mine still did, i didnt touch any of the wiring just plugged straight in :)
Yup. You can have the OEM tweeters running as well if you don't snip the wire. I did mine because there are no crossovers anywhere and the tweeters weren't sounding wonderful. The tweeters in my Pioneers are miles better.
The front and rear speakers are 6.5 inch. But the rear ones are quite shallow hence the window catching. New adaptor to bring them further out like the front ones does the trick.
southern smoke!!!
