reefer24131
131
kent
as title says...
we have a 2008 2.0tdi passat in work thats failing to start, only fault code coming up is camshaft sensor (g40) and i think thats to so with excessive cranking, however we have changed the sensor. the customer was driving the car and it cut out on her.
we beleive its either an injectoe problem or crankshaft sensor. Can vagcom/vcds run any kind of tests to locate the problem?
found the problem, fault code was saying camshaft sensor out of range and that was because the tining had jumped a couple of teeth somehow, so guess what im doing doing next week?...argghh!
