stealth_boy
Sunday, 13 February 2005, 19:39:55
VAG-COM Version: Release 409.1-S
Control Module Part Number: 6K0 906 032 AA
Component and/or Version: 1.8L 20VT EU3 0002
Software Coding: 10500
Work Shop Code: WSC 00000
12 Faults Found:
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 35-00 - -
17955 - Boost Pressure Regulation Valve (N75): Short to Ground
P1547 - 35-00 - -
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
P1117 - 35-00 - -
17843 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 35-00 - -
17829 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
P1421 - 35-00 - -
Grateful for any help on this one guys cheers
Gav
17697 - Boost Pressure Control Valve (N249): Short to Ground
P1289 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
17523 - Oxygen (Lambda) Sensor Heating Circuit: B1 S1: Short to Ground
P1115 - 35-00 - -
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 35-00 - -
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-00 - -
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-00 - -
12 Faults Found:
P1425 - 35-00 - -
P1547 - 35-00 - -
P1117 - 35-00 - -
P1435 - 35-00 - -
P1421 - 35-00 - -
Gav
P1289 - 35-00 - -
P0102 - 35-00 - -
P1115 - 35-00 - -
P1114 - 35-00 - -
P0134 - 35-00 - -
P0140 - 35-00 - -
