AP Lowering springs with shocks.
paulos44
537
Warwickshire
Hello all......
Had the SP81-009 40/30 lowering kit fitted to my Toledo20vt 4 years ago, and am about to have the second replacement spring fitted tomorrow, due to the first 2 breaking.
Has anyone else had problems with AP suspension springs breaking ?
I will add that I do only about 6000 miles p/a and always go over speed humps very slowly, probably about walking pace.
hombre_paulo
157
If its any condolences I've just had a spring snap on my ST by KW kit on my LCR. Only done 50k in 5 years
paulos44
537
Warwickshire
I have a feeling that these aftermarket springs are nowhere near the quality of the original springs........poor quality steel, poor tempering etc.
bruceR
2,540
616
Monifieth, Dundee
For that price get both sides done - always advisable to replace both sides of an axle at the same time
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
When I came to change springs on my old Cupra I had 2 that had snapped. Proper pain.
Badger5 Custom Map + TIP,
paulos44
537
Warwickshire
I've just had the wheel off and had a look......shock looks easy but changing spring will deffo require spring compressors.......garage can do that.
BigJase88
Jase
Apr 20, 2008
3,767
1,069
Is it not a rear beam?
Unbolt bottom of shocks and out pops the spring
very straight forward
No spring compressors req for rear just a trolley jack to take the compression of the spring
BigJase88
Jase
Apr 20, 2008
3,767
1,069
Tried that but the suspension arm wouldn't drop low enough to get the broken spring out.
You need the rear on axle stands on the sills and then unbolt both rear shocks at the bottom, with a trolley jack under the spring cup to take the compression then lower jack and voila spring will almost fall out.
refit is same as removal but in reverse, use trolley jack to get the spring compressed enough to slot the bolt into the bottom of the shock
