APR air flow logs
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
that would be why then! wont be sucking in as much air!
log block 115 to see what boost ur running.
i just literally did some logs...
got 200.14 g/s in 3rd.. lol it is a bit worm tonight tho! :lol:
wild willy
2,323
Wales
Did a couple of logs the other day when SCN was down:( and using 3rd gear I got 190g/s. Then using 4th gear I got 187g/s both identical runs one after the other:shrug:
I get identical measurements also when using 3rd or 4th gear.
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
you will get similar results, buy doing it in 4th it will be able to record a lot more data as it will take the car longer to get from 2k rpm to the limiter in 4th than in 3rd.
and thus the more data available the better conclusions you can come to!
bentaw
Revo'd LCR
Oct 1, 2004
1,067
Hampshire
i am running boost 8 and still only getting 176.2 g/s but the car flys with no problems, pull back or limp mode what so ever and it is pulling 1.55bar of boost on vag com but settles at 1.45
