Right I got the car back from Jabba with 323bhp but it had issues, after fixing everything, giving the car a service, fitting the correct air filter and running a new MAF I got 343bhp at Awesome GTI (which usually reads the same, if not a tad lower than Jabba).
I have never had the Forge with IHI, I was getting high enough temps with a K03, however what I've said in the past to Pete is don't just go get the Jabba FMIC because you think it'll be ten times better, compare a few things first... I have yet to get Jabba FMIC logs.
I had a few issues with Jabba regarding my car and some of their work, but I resolved the problems and they resolved my problem with them by supplying the correct filter £FOC. My car never was right when it left Jabba and I personally feel the readings their may have been a little down, I still want to take the car back for mapping later on to see if it can pull a little bit harder.
Also remember both mine and Pete's have a years warranty on parts and work, so untill thats out the way Jabba may map conservativly.
i spoke to jabba about half an hour ago.. nick wasnt there who i delt with but asked them wat the process is.
1. do they safety map it a little bit
2. could it have been mapped a bit harder etc
they said they will call me back, im also waiting on a filter comin off them as they sed the one on now had a slight tear in the rubber or something.. which i havent recieved yet.. so il wait on their reply and see what they say and let you know as and when i do.. would be interesting to see some logs from ur jabba cooler craig as my intake temps do get rather high
Also would you need to bore out the 1.8 head to 1.9 to reduce lag?
bore out the head ????? that wud be a laugh
you can bore a block to 1.9 or port/polish a head but not bore a head to 1.9! lol
pete, im gonna b doing a GB on pro alloy FMIC so get one then!
HoocH
HoocH
lol sorry, my bad:doh:
I meant the block!:p
awesome hooch any more info on them?? but yer i cud be up for that.. was on the phone to awesome earlier and they sed that my intake tamps r far to high and that they will affect my performance so maybe is time for better fmic"
Right i have made a decsion, iam sticking with the original plan of the GT2871R. From what i keep reading its a good unit, very responsive etc. I can accept a bit of lag.
For those of you who haven't read the whole thread i have the following parts coming for the Mega Beast.
ATP GT2871R
HoocH motorsports DP (lol)
Genesis 550cc injectors
Jetex Cat Back exhaust system
Mahle Motorsport Low comp Pistons (std bore)
THS Conrods
Inconel Valves
G60 Flywheel
VR6 Stage 3 clutch
Heat wrap for DP
Wideband Lambda setup (innovate)
Personally i'd look at running water/meth injection before changing the whole FMIC. You can get Snow Performances WMI stage 2 kit delivered for about 225-250 quid which will get the temps down loads.
I already run Aquamist 1S system with race pump, with 15% methanol mix. :)
ATP GT2871R
THS Conrods
Inconel Valves
G60 Flywheel
VR6 Stage 3 clutch
Heat wrap for DP
HI Matt
just curious to know why you chose a Jetex system? had one on my old ibiza, and it was very good, but I dont hear of jetex very much on the ibizas anymore
i run the jetex system on mine and work a treat is a really good quality exhaust and sound pretty cool to.
HI Matt
Basically mate, i love pete's, it sounds totally fantasic when pushing, and i wanted to go back to the original 2 round tailpipes, + i got it for £ 280 delivered :funk:
you know the score young matthew! get that god dam cat out of it so pops and bangs like mine to.. infact wud do it more than mine i wud imagine!
Same issues with jabba as normal,i had a forge ic on my s3 and it was no restriction at all,very very good bit of kit,363bhp on jabba dyno.
Its gonna be decat anyway mate, will remove centre box like yours too. Dont want it to be louder than yours fella, yours is like a shot gun going off.
Cant wait.
