hey paul my mate have an s3 and want to uppgrade his engine mounts. he is around the 300 mark. you know some good engine mounts??
Fitted it back on the car and did a couple more runs.... got an airflow of 291g/s!!! same setting on the MBC, just a de-meshed MAF...
Not a bad increase for a hours messing about... 270 to 290 g/s
There is some discussion on another thread about the validity of this increase and the MAF ability to now accurately measure the airflow now that it can no longer be stabilised by the mesh screen... I am on the fence with this, I am not convinced it would over read the air but under read if anything at all. I will be logging block 001 amongst others to keep an eye on real time ECU correction to fuelling and keeping an eye on long term fuel trims to see if fuel is being removed or added in any great quantities that would back up a misreading MAF.
Hoping to get the new MAF, lambda and finally my EGT probe sorted next weekend if I and of course Bill can find the time.
Car is driving great at the moment, feels stronger than it has done in a long while... I is a happy chappy
<tuffty/>
, and yet has no problems pulling out 600hp on turbosetups....another thing to take in to consideration is that HGP turbo of germany only tunes with stock AIR box and STOCK airfilter, and yet has no problems pulling out 600hp on turbosetups...
I was at the essen motorshow in december 2009 and i saw some VW MK 5 setups on the 2.0T fsi, they used the standard air box but with high performance panel filters and were producing 350+Hp.
This makes me wonder if Induction kits really make any difference.
you can make those power levels, but it does'nt mean you cant get more from an open cone.
its proves nothing..
compare one, swap over and compare again, same car then you will know
What will be causing this vortex you describe on the intake path of a std airbox which has intergral bell mouth
Open MAF could indeed flow less than an airbos which runs radius bell mouth.. think of aero jet engines intake.. and they pick up 30+% flow efficiency from their intake bells..
you are right about the purpose of the screen to help laminar flow across the sensor element, however, down stream mesh serve no purpose at all.. and upstream with 5-8 diameters worth of pipe will also yield smooth flow across the sensor with or without the screen/mesh. mesh would look to just be a parge pore particulate filter, and the screen is what guides flow into laminar across the sensor.
as for over stressing a sensor, I see no causation for this at all. it remains a temperature device as before reacting to incoming airflow and its cooling affect.
very high airflow can and will damage the sensors hybrid circuit, when it cannot normalise its temperature relative to the internal reference.. and then the hybrid fails and dead maf syndrome.. nothing to do with quality of air passing, more quantity.
tuttys on the edge and slightly beyond on his turbo on the 80mm maf, and is more likely to fail for the reasons I have just described above. RS4 larger maf next and slow the airflow across the sensor so the hybrid is within its 0-5v output range. tufftys actual output when I checked months ago was 4.98v which was above map scale for this sensor back then.
The new style MAF's (MK2 LC) don't have any screening.
I haven't looked closely at the design but the MAF is very different between the MK1 and MK2 Leons
...Oh - and cheers for the joyride last night Paul, muchos impressed![]()
Where did you get the heat wrap from for the downpipe?
Good job! Nice building of your Audi S3 GT3071R. I want to ask its Air filters? How and what did you do about it?
