AUQ K03S hybrid silicone TIP problem
Livemech
Hello,
I know there is loads of forums with installation guides about the TIP to AUQ engine. But I am having a hybrid k03s with k04 in it, bought a silicone hose, oversized with 51mm turbo diameter. But when I try to install it, the pipe is touching a gear linkage mount and I am afraid it will rub it down from vibration in engine. Anyone had same issue? Any advice or is it a wrong shape of TIP? Any suggestions would be good :) Thanks
jamfull
157
Water pipe and gear gables had to be moved on my hybrid .go to sponsors section badger 5 have a read of the ko3 plus hybrid thread in the stickies. Lots of info there.
Sent from my Hudl 2 using Tapatalk
Livemech
Thanks, I have been thinking about moving the linkages aside. Any pictures you could give a rough idea what I am doing?
