Autoclosure and window fold not working
fabiavrs2004
65
Bristol
I'm sure I've seen it somewhere but can't find it. My 2015 FR has stopped auto closure on windows and folding in the mirrors when holding down the lock button. I've tried opening and closing each window several time but still joy. Any clues.
Walone
1,563
429
Near Heathrow
Think you need to perform the setting of 'one touch' lowering and closing.
I'm sure it's in the handbook.
Walone
1,563
429
Near Heathrow
One-touch opening and closing*
One-touch opening and closing means you
do not have to hold down the button.
Buttons ››› Fig. 137 1 , 2 , 3 and 4 have
two positions for opening windows and two
for closing them. This makes it easier to open
and close windows to the desired position.
One-touch closing
– Pull up the window button briefly up to the
second position. The window closes fully.
One-touch opening
– Push down the window button briefly up to
the second position. The window opens
fully.
Restoring one-touch opening and closing
The automatic open and close function will
not work if the battery has been temporarily
disconnected. The function can be restored
as follows:
– Close the window as far as it will go by lifting
and holding the electric window switch.
– Release the switch and then lift it again for
1 second. This will re-enable the automatic
function.
If you push (or pull) a button to the first
stage, the window will open (or close) until
you release the button. If you push or lift the
button briefly to the second stage, the window
will open (one-touch opening) or close
(one-touch closing) automatically. If you operate
the button while the window is opening
or closing, it stops at this position.
adstalker
43
Darlington
I've had this happen a couple of times on my car. You need to re-do the one touch lowering and losing and everything should return to normal.
I did notice on my car that the red led alarm light on the passenger door stayed on continually when this happened and I needed to reset the system.
In 3.5 years of ownership, this has happened to me twice.
Reactions: TollyBhoy
