Going to contribute with my thoughts on the Awesome clutch option. Sorry for the long post in advance.
When my clutch started to slip started researching options. The hardest bit is trying to judge whether the flywheel would need doing however I didn't risk it and just got it all changed. The car is a Leon Cupra R running stage 2 power and used as a daily driver. On top I like to use it how it's suppose to be used, 1/4 mile runs, couple of track days planned for 2012 which is why I needed something a bit more durable than the OEM setup.
An option would have been the LUK dual mass flywheel and Sachs performance clutch which I was finding for around £600+ for the rigid friction plate and pressure plate.
Other options which were getting raved about were the uprated Southbend clutches which work with the LUK DMF.
Alternatively there was the single mass flywheel options. The obvious concern with these seem to be the noise factor. It chatters on idle. On the opposite side of things the car will rev more freely so revs will increase quicker due to the lighter option of the SMF however revs will also drop quicker which comes to another concern when it comes to gear changes and keeping the revs up. Nonetheless the options I felt best suited my needs for the SMF route were:
- Southbend clutch kit with single mass flywheel
- Helix clutch kit with single mass flywheel
Finally the last option I started looking at the newly put together kit from Awesome GTI.
When I spoke to Al at Awesome he gave me a lot of reassurance with this kit. There are three bonus sides to it also:
- Price: a very wallet friendly £625 for such a heavy duty clutch
- Feel: seems that it is not far off from the standard clutch feel so using it as a daily should be all good
- Noise: according to them and the reviews there is no chatter noise like usual single mass flywheels (not that it bothers me if it did)
I looked around online to find those with the same kit but couldn't find any LCR owners at the time. I did however find several others who were running these on highly tuned cars. I decided to take the punt and go for it and I am so glad I did.
Great bit of kit, it has taken everything I have thrown at it so far and as mentioned previously I do like to give it some beating
No chatter, minimal vibrations when trying to get going at very low rpm but that is it.
The one thing I did notice when research for clutches is the amount of advice from those who's mates are running a set up. I personally don't think it is a good idea to make statements unless I personally have experienced the product etc. Good luck to anyone looking to change clutches, but if your needs are similar to mine then I would recommend looking into the offering by AwesomeGTI
