Back brakes sticking on, and weird rubbing noise when reversing
crunch463
Sorry if this has already been covered i have searched to no avail, when LCR has had handbrake on the rear shoes seem to "stick" to the discs, ok as i pull away it frees off, but also while in reverse i get a squeal slash rubbing noise, i do have brembos with grooved discs set to aggresive? This may be why when in reverse i get a noise as the discs have worn one way but im not sure?
Any pointers advice or abuse eagerly awaited x
Dec 5, 2012
806
Harlow
My mate who also has a LCR had the problem with the rear brakes sticking. He sprayed the calliper with penetrating fluid. (Not the disc or pads bad idea) he said the callipers no longer stick so try this.
crunch463
Looks like springs are on order, i will try the cheaper alternative of servicing the ones i have but springs key i think
adamjb
23
North East UK
I have got same problem but I'm unsure if I should rebuild my calipers as kit from TPS seems fairly cheap or just fit springs on my calipers? will rebuilding help me with my problem for a longer time or should I expect my handbrake to stick again? opinions please ;)
crunch463
I am lead to beleive that a spring repair will resolve this issue as long as said spring is maintained,
Dec 29, 2010
1,115
Mids
As recent thread for rear callipers that was running around 1 week ago search sticking rear callipers....these are the part no for the 2.09 springs I've used they aren't for cupra r as they are somethink stupid like £15 but these are vw and will do the job v7ho 615 295a and v7ho 615 296 I've got the thread subscribed but won't let me copy and paste it sorry
Sent from my iPad using Tapatalk HD
