IbizaAlex
AKS tuning
May 11, 2008
532
Bedford
Ive been asked to get the thread going on the recent build so here it is.
The kit have never been fitted to the Ibiza and as i have a donor car it seems a perfect opportunity. We have had to make a different downpipe and cat/de-cat section and intake, but its all gone very well. Some piccys:
The turbo and manifold have to come off to fit the downpipe in. I think i must have had it off 20 times while making and tacking up the pipes.
As you can see the 3" pipe fitted fine
Finished product. It takes fooking ages to polish all the pipes up. I still want them shinier, but i will do all that when is all comes off to be jigged.
Alex
Its on Revo Stage 3. Im running 1.5 bar boost at the moment so at a guess it should be around 330bhp. I will get in on the rollers.
Turbo does sit nice and high. I like it that way to show it off!!! ;)
Lol
doesnt it get hot though,and its very close to the bonnet?
330bhp is perfect! have you done your internals or keeping it that level so you dont have to?
are you running a limited slip diff? soo many questions lol sorry
Lol
It does get fairly hot, but the carbon helps ;)
Internals are standard. Im sure it will be fine running slightly more power still so i will be upping it more to test.
I run a Peloquins ATB diff. Still has a little trouble getting the power down in 1st and 2nd.
Nice clean setup, well done.
Cheers :)
Small update. Removed the aircon this morning. As the Ibiza will shortly be my 2nd car so i wont be using it that much i thought feck it. Was very tight getting the pipes out due to the turbo and downpipe, but i never give up.
Ive also been having clutch issues. Something isnt right, but im yet to take the box off to investigate. The clutch just wont release enough to get gears. Ive tried bleeding and replacing the master and slave, but still the same issues. The pedal feels perfect tho. It could be the pressure plate has broken down, the friction plate has dissintergrated or the rivets in the fly have started to come out. I did have to drive 30miles home without being able to use the clutch. There was crunching involved a few times! :headhurt:
I bought a GT28RS and manifold from Backdraft - make sure you run an oil restrictor with this turbo. Backdraft didn't advise me that I needed one and the turbo went Bang after only 8000 miles.
Learn from my mistake otherwise it will get expensive ! My Car is mental !
sorry m8 im back on my own computer now. what was it your after? pm me ive cleared my inbox now.
i have your old gt2860 kit 2 m8 havin it tweeked soon by badger5.
how did you get the manifold on do you have 2 mod any spanners 2 fit? its tight only havin prob with 2bolts on mani and im away :)
Will be the downpipe and de-cat/cat become a stock item from backdraft, if so what sort of prices would we looking at?
We have never had one go from not using an oil restrictor (We do use them now anyway BTW). They can fail even when using an oil restrictor. It doesnt mean it was that that was the issue.
They can all be done with a normal 12 or 13mm spanner depending on the bolts used.
It will be once the jig is finished. Im not fully sure on prices yet, but i will get them sorted before PhilW comes to shoot me!
