Balancing judder after new brake discs fitted
BEEFYGTI
625
Port talbot, south wales
Hi' I am a bit confused at the moment , I have just had new brake discs fitted and have noticed that I am experiencing juddering after approx 75mph? I do understand this. Any ideas
Feb 1, 2007
1,602
Nottingham
Lets assume the discs have been fitted correctly and the appropriate make, it does matter!
Its likely to be high spots on the pads, give them a while to settle, usually 200 to 300 miles.
Check the caliper sliding pins are tight too.
big rich
VAG techie
Apr 22, 2011
487
south yorkshire
well my crystal ball isnt working at the min :p but...
i bet when they took the wheel off they caught it on the back plate for the disc its usually enough to knock off a balance weight or make it loose so when you drive down the road it drops off. Its that or they have left the wheel loose or something.
