Yeah can't wait for the sun to return lol
A final pic of the day
have u spaced out your front wheels now too mate? looking at spacing mine but was going to hold on until ive got my cupra r hubs etc on to see if the wheels sat any different
loving your car by the way bit of an inspiration for me at the mo to pull my finger out
Cheers buddy:D I'm running 10mm front spacers and 15mm rear spacers. I'm not aware of the hubs making a difference. Might be worth sending someone like Phillc a pm and asking.
Good luck with yours, I'll try n keeP up the inspiration for you ;)
Small Update:
For Christmas my misses got me a short shift for the car.
Took all of 10 minutes to fit.
Amazing difference! Really happy with the result.
done my cupra conversion mate hubs dont make the wheels sit any differnetly but the the front does sit lower get yours on mate the car handles so much better!
I FINALLY managed to clean my car today. Much needed nearly 500 miles put on it over the Xmas period.
From this all over
To this :)
Results of a couple of logging runs last night
Code:
	Group A:	'003				Group B:	'020
		Engine Speed	Intake Air Mass	Throttle Drive	Ignition		Cylinder 1 Ignition	Cylinder 2 Ignition	Cylinder 3 Ignition	Cylinder 4 Ignition
	TIME			Angle Sensor 1	Timing Angle	TIME	Angle Delay	Angle Delay	Angle Delay	Angle Delay
Marker	STAMP	 /min	 g/s	%	 °BTDC	STAMP	 CF	 CF	 CF	 CF
	0.01	2760	70.39	69	24	0.4	0	0	0	3
	0.8	3000	112.53	100	10.5	1.29	0	1.5	1.5	3
	1.69	3360	108.78	100	8.3	2.11	1.5	3	1.5	3
	2.51	3680	121.31	100	12	2.91	1.5	3	1.5	3
	3.31	3960	144.17	99.6	11.3	3.71	1.5	3	1.5	3
	4.11	4240	135.78	100	11.3	4.52	0	3	1.5	1.5
	4.92	4520	157.58	100	12	5.32	0	3	1.5	1.5
	5.72	4760	146.86	100	12	6.14	0	2.3	0.8	0.8
	6.63	5040	158.19	100	15.8	7.13	0	0.8	0	0
	7.64	5320	167.33	100	17.3	8.04	0	0	0	0
	8.44	5520	174.58	100	16.5	8.96	0	0	0	0
	9.45	5800	173.75	100	16.5	9.85	0	0	0	0
	10.25	5960	174.86	100	16.5	10.66	0	0	0	0
	11.06	6120	162	100	19.5	11.46	0	0	0	0
	11.96	6240	159.39	99.6	21	12.38	0	0	0	0
	12.78	6360	164.64	99.6	18	13.27	0	0	0	0
Code:
	0.39	2920	106.69	98.8	12.8	0.01	0	1.5	1.5	3
	1.19	3280	124.42	100	9.8	0.8	0	0.8	0.8	3
	1.99	3560	120.83	100	12	1.6	0	0.8	0.8	2.3
	2.81	3840	122.14	100	15.8	2.39	0	0	0.8	2.3
	3.61	4160	147.61	100	12.8	3.21	0	0	0	1.5
	4.51	4480	143.36	100	13.5	4.11	0	0	0	1.5
	5.42	4760	162.28	100	13.5	4.92	0	0	0	0.8
	6.22	5000	152.56	100	14.3	5.82	0	0	1.5	0
	7.04	5240	165.56	100	15.8	6.62	0	0	1.5	0
	7.95	5480	171.31	100	17.3	7.53	0	0	0.8	0
	8.75	5680	174.75	100	17.3	8.35	0	0	0	0
	9.66	5920	174.97	100	14.3	9.24	0	0	0	0
	10.55	6080	159.69	100	20.3	10.06	0	0	0	0
	11.37	6200	162.56	100	19.5	10.96	0	0	0	0
	12.26	6320	178.81	99.6	15.8	11.86	0	0	0	0
	13.07	6400	170.58	39.6	6	12.66	0	0	0	0
Cheers Tim :)
Well as you can all see, my g/s are fluctuating like nobodies business. Can anyone confirm that this is down to a faulty N75 valve?
When driving the boost is constantly up and down all the time surging between about 14-18psi. (you can see this is the g/s)
have you got a cupra r antiroll bar mate? i have aqquired another one whislt scrap yard hunting
I havnt what's the difference just diameter and mounting points? Was looking at neuspeed ones hadn't looked at OE LCR ones
mounts to subframe the same but the links go to the shocks not sure on diameter its at home i have powerflex bushes too that i took off mine when i superpro'd mine
Blew a coil pack on the way to work today :( luckily I phoned my local and very helpful seat helperouta man (phillc) and he sorted me out a treat! (thanks Phill)
So after work i went to see Phill, got the parts i needed along with the N75 valve thats been faulty for quite a while.
Started my journey home only for the misfire to get extremely bad to the point of not being able to drive it so another call to Ronin225 and he came shooting over with vagcom and helped me sort it out (cheers Tim) so: Replaced coil pack
Replaced faulty N75 valve
Got in the car and drove with a big smile on my face. Thats my short story for the day lol :)
what fault did the n75 give?my leon seems to stutter under boost was thinking about changing this bit lol
The N75 kind of regulates the boost for example when mine was faulty it would peak at 22psi then drop to 18 then surge between 14psi and 20psi. It was literally a split second thing but would keep doing it.
Stuttering under load sounds more like a coil pack failing to me however I could be wrong.:shrug:
just had 4 new gen ones fitted, only seems to play up since having new turbo,but going to get a hybrid soon so will see if that helps lol
