Small update:
I've had niggly problems building up over the last few months and today I set about sorting them all with the
help of Tim.
I replaced the ABS sensor that failed on the 30th October!
While doing so realised the pads were well overdue changing so fitted some new ones that I happened to have to get me by, this alone turned into a nightmare as 2 of the pad retaining pins were seized!
this got worse when I checked the discs out and realised they also need doing!
I checked the lower arm bolts as I have a small knock ocassionally.
Finally Tim spent a few hours doing all 4 of my door seals and vagcoming his way through my fault codes, as well as checking my oils and fluids while I was putting the wheels back on. (Thanks mate)
I've got a few small things left to do but the major work is done
