Battery charging
cuprabod
649
7
Cheshire
I will need to put my leon 2017 fr 150 on trickle charge , the positive goes on battery but should the negative be connected where the black ĺead on the bulk head is behind battery , cheers
Jim45
316
86
Yes, connect to the earth point rather than the battery earth.
In all honesty if you are using a CTEK charger which is ‘spark free’ you can connect directly to the battery, they only tell you to connect to an earth point for approval reasons.
Seastormer
Cupra Leon VZ2 300/CBF1000
Apr 25, 2014
5,375
873
69
Edinburgh (Scotland)
My Optimate charger has a permanent connector attached to the Cupra battery, with a lead that the charger just plugs into when required, Do the CTEK ones not supply that also?
