cuprabod
653
7
Cheshire
I will need to put my leon 2017 fr 150 on trickle charge , the positive goes on battery but should the negative be connected where the black ĺead on the bulk head is behind battery , cheers
Yes, connect to the earth point rather than the battery earth.
In all honesty if you are using a CTEK charger which is ‘spark free’ you can connect directly to the battery, they only tell you to connect to an earth point for approval reasons.
My Optimate charger has a permanent connector attached to the Cupra battery, with a lead that the charger just plugs into when required, Do the CTEK ones not supply that also?
