Battery Issue
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
My battery is on its way! as it showing low on battery tester!
Any suggestion on any good places beside halfords i could get it from, prefer heavy duty!
does a low battery effect the car performnce, mpg?
mc
Jan 15, 2006
100
Birmingham
I'd have thought that it wouldn't affect your mpg, because your battery is only used for starting, and the alternator should supply enough for the car and re-charging the battery once on the move?
how old is the battery? can you top up the electrolyte as a temporary measure?
I don't know if Car Spares distribution do good batteries?
Big_daddy
Oct 20, 2006
3,930
Brummy
MMM not sure! Its Bosch battery Theres a Green circle window on the battery! why is that there for?
mc
Jan 15, 2006
100
Birmingham
older cars had little plugs you could remove from the top of the cells, probably six to unscrew, or maybe a cap that would come off. if theres nothing obvious it's probably sealed for life. I think the green dot means it's almost fully charged?
are you measuring the acidity to know its almost dead or is it just sluggish to start the car?
Big_daddy
Oct 20, 2006
3,930
Brummy
my battery tester has 3 lights! Red (Low), Orange (Medium), Green (full).
When the car parked over night, it stays on orange! When i start the car it goes to red! takes abit struggle startin!
Onced it started it goes full!
After its been turned off for around 2hours or so, it goes to orange!
The alternator fine as i could measue it, it is charging correctly"
Skorchio
600 Miles to a tank :)
Jan 23, 2007
1,570
Nr Milton Keynes
Yeh sounds to me like ur bat. If whe the cars running it shows as green then u know ur alternaters working. How old is the Bat? Should be replaced every 3 or so years. Wont affect ur performance at all like MC said.
mc
Jan 15, 2006
100
Birmingham
Yeah, I'd say best to change it.
its normally the heavy use in cold weather that kills batteries... lights, rear screen etc.
over a year ago I could feel my battery starting to struggle because I was only going 10 miles a day during February. But since then it's been fine because of the longer runs. You may just get away with it but i'd change it just to be safe!
Big_daddy
Oct 20, 2006
3,930
Brummy
Cool guna make a trip get a heavy duty battery! My sub goin back in and dont fink this one willhave a chance of survivin!
Big_daddy
Oct 20, 2006
3,930
Brummy
This sub is only 1000watts so it should be fine ona heavy duty battery!
My previous subs it defo would not last! the pioneers run at 6000watts power!
Skorchio
Jan 23, 2007
1,570
Nr Milton Keynes
yeh i bet with that kind of power. I used ot be in to big installes now i just like tidy onces where u can still use the boot (much be old age) :(
Big_daddy
Oct 20, 2006
3,930
Brummy
Im abit def :p so dont want get anyfin louder! the neighbours will complain! and i be need my own generator never mind a power cap!
SWANSWAY CUPRA Dealership
