Oct 24, 2019
So on the way home warning light for battery came on saying that its not charging and that i should stop. Came home turned the car off and on warning light gone off should i be worried?
Multimeter on terminals of the battery while the engine is running. Should be around 14.4 volts. If not then alternator is goosed.
With the engine off the battery should be minimum 12.4 volts, anything below this indicates new battery time
Well, here is the thing, what you said about battery voltage when the engine is running is correct for a car without smart charging, for any car with smart charging, and the system working as intended, you will normally see only 12.6Volts maybe while driving under power, on the over run you could see something a lot higher than 14.4Volts as the charging system crams charge back into the battery on the over run and especially while braking.
Sort of regenerative braking to improve emissions.
Every day is a school day
didn’t know this
Neither did I fully until I drove around with a DVM connected to a "cig lighter" plug in the 12Volt socket, quite large high voltage variations - I did know what it was expected to do, but seeing is believing.
