best lcr 225 dump valve
c6hut
As the title suggests, want to know what you guys recommend to be the best dump valve for my 225 leon.
Sounds like a right dumbass question, but what benefits and sound will I gain with it.
cheers
andycupra
status subject to change
The first thing you need to be aware of is the search function on here. There is loads of information and this question is asked virtually daily.
The second thing is that the 1.8 20vt uses a recirculating diverter valve, which means the diverted air goes back into the intake and not out the asmopshere as with a dump valve. (most people just call all valves dump valves).
So in short, this means they are quieter than the loud dump valves but do work efficiently as air is not 'wasted'.
On this forum you will get one answer to your question, the Forge 007p. A piston type diverter valve thats a straight replacement for the original item. You may detect a very slightly more positive action. Louder? not in my experience, some have reported fitting it backwards gives more sound, some not. However this item will more than happily cope with all you can throw at it, remaps, more boost, or whatever. The original valve is plastic and has on occasion be known to fail.
There are of course other valves, but the forge is proven to be effective and very reliable. IF you are unsure of the price keep an eye on the for sale section.
If you wany sound you may get told to get a dump valve to atmosphere, but please dont. The ECU expects the air to be reused, and if its not then the readings achieved and expected will differ. You may be lucky and its within tolerances, but you may not be which may lead to not obvious issues.
Forge also do another valve thats part recirculating and part dumping (split-r valve) but it is significantly more expensive and from what i have seen the feedback has not been fantastic.
If you want more sound, then invest in an induction kit such as the BMC CDA.
caveo
Please dont enrage me by buying a split-r valve , they're shite.....end of.
Dec 3, 2007
2,475
cardiff
im not trying to cause an argument but you want a good sound while still doing the right thing and recirculating the air then get a turbosmart dual port kompact. they are costly but sound amazing and will put a smile on your face while still being good to the car
i talk from experience and can back this up!
caveo
If it vents any amount to atmos it will increase the lag between gears ...end of.
Dec 3, 2007
2,475
cardiff
the whole point for a bov in the first splace is to let the turbo slow down rather than keep it spinning or stalling, so a small amount is not going to make a big difference!
caveo
As you can see i have a big turbo set up and when i had the split r you could feel the car loose all momentem at gear change so i set it back to full-recirc and the car was alot smoother and quicker , try it and then get back to me.
Dec 3, 2007
2,475
cardiff
Split R works , end of chat , just needs setting up correctly
we have NEVER failed with a single installationn .......................jesus
Thank you! They are not the easiest to set up but i have managed to set up a few. Obviously you wouldn't make them and advertise for the car if they didn't work. And i think u do know your stuff.
caveo
Oh they do what you say ..... you just forget to tell people about the increase in lag between gears and call me caveo not jesus lol.
