Best oil for 2008 1.9tdi leon
Williamoconnell
Mark 2 leon
Mar 7, 2015
Hi,
I have a 2008 1.9tdi Leon stylance, pre facelift model , it has the BXE engine fitted 105ps
I don't think the car has a dpf fitted , what is the best oil to get for these engines? 5w40 or 5w30
William
-UzY-
91
I recently serviced my car (1.9tdi Stylance) and I was recommended to use 5w30 fully synthetic long life oil
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
It's a PD TDI so you need an oil that meets VW 505.01 as a minimum. VW 507.00 will also protect the engine but is more expensive, and is specced for engines with DPF.
Just going by the viscosity rating is a *very* bad idea with a PD engine.
This Opie Oils page gives you a few to choose from. I'm using the Castrol Edge Titanium 5W40 in my BKD Altea - but I got it from Euro Car parts who had it at a much better price. If you look elsewhere, just make sure it has "meets VW 505.01" on the bottle somewhere.
Williamoconnell
Mark 2 leon
Mar 7, 2015
I take it VW 507.00 exceeds the VW 505.01 standard?
I think 5w30 507.00 longlife quantum oil should be okay
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
From here
VW 507.00:
Low SAPS oils suitable for Euro 4 engines and almost all VAG diesel engines from 2000 onwards with extended service intervals, unitary injector pumps and also Pumpe-Düse ("PD") engines.
verbal_kint
639
31
North West Kent
Opie currently has Fuchs Titan at £25 for 5 litres hits is 505.1 approved.
I believe your choice of service interval can impact on the choice of oil.
DiddlyDonker
323
North Wales
From here
VW 507.00:
Just a quick question, sorry for hijacking the thread, what about my 56 plate PD170 Leon FR? It has had the DPF gutted and reading that site it goes on to say:
" Excludes V10, R5 engines and VW Commercial vehicles without fitted DPF (diesel particulate filters) – these must use a 506 01 specification oil."
That is under the VW 507.00 specification oil. As I've had the DPF removed do I now need the stated 506 01 oils or do I still use the 507.00?
Thanks.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Do you have a V10, an R5 engine or a VW commercial vehicle without a fitted DPF? If not then you don't need 506.01.
I suggest you ask the question on the Opie oils section of the forum, where you will get much better advice than I can give. But I'd suspect you can go with 505.01 on fixed service intervals if you don't have a DPF.
