I have been doing some logs on my car since getting the APR remap and based upon the results and a known comparison have com up with the following conclusion.
A lot of us on here believe that the BHP of a car can fairly accurately be calculated from the MAF by varios simple calculations such as G/sec x 1.31.
However I have don runs in 3rd and 4th gear to the redline and found a maximum Maf reading of around 170 - 174 G/sec and at using GaryM's car as a comparison ( sorry to pick on you Gary) his car is almost identical in spec to mine and is running custom code 2, his Maf reading is around 187 g/sec and I have recently seen a maf log of DPJ on here getting similar MAF figures but running only 188bhp and 109 lbs ft torque.
Here raises a question......Gary's car runs 19PSI boost and DPJ with Revo is running 21PSI my car is running around 16-17PSI why is the Maf reading consistently lower?
My power and torque curve was plotted by awesome against Gary's car and they are almost identical.
Mt thoughts on this....and I stand to be corrected by some more knowledgeable guys on here....is that the Turbo is a compressor and as such the faster the turbo spins ( within it's efficiency envelope) the more boost pressure it produces and the more volume is moves through it.
It it well documented that more boost ( hence more volume through the MAF ) does not always equal more power so this brings me back to the MAF,
if my car is producing 212 ATW and producing 250 lbs ft torque but only moving 170 G/sec through the MAF @17PSI boost,
GaryM's car is producing 216 ATW 255lbs torque moving 187g/sec through the MAF @19PSI Boost and
DPJ's car is producing 188 ATW 209lbs torque Moving 186g/sec through the MAF @21PSI Boost
Then the correlation between MAF reading and BHP goes completely out of the window so how can the BHP be calculated from the MAF figure?
all these readings are from Awesome's RR so there is consistency in the RR.
Open to discussion.......
I'm going to try to get some acceleration calcs done to calculate bhp on the track.
