cupra-8v
102
Hello all, just wanted to know what is the biggest size discs you can get onto a cupra 8v with standard setup? Also whats the easiest route to go if mods are needed.....
Thanks,
Chris
With standard calipers? you can't you will need to upgarde it all. 16v which are 280mm you have 256mm at the moment with the 16v calipers will bolt on.
Brembos & 305mm from the Mk3 Cupra R (which I have) will go on as long as you have the carriers for the brembos.
