I've noticed what I can only describe as black stuff/bits coming from the screen wash liquid.
It's a bit like flat chippings of rubber that drys flat, but more like dirt when you try to remove it. Stays flaky if you rub between fingers.
I thought it was coming from the wipers that were on their last legs but these have now been changed.
The car was in for service yesterday and where they have tried the washers including the headlight washers it has been sprayed all over the bonnet and window.
It's doing no harm but curious as to what and where!
The only thing I can think of of is a few weeks back when we had that cold weather it was -6 and with the car outside it froze the screen wash and pushed the headlight washers out about an inch/25mm at worst case.....could something like a seal or seals be breaking down?
Currently running the standard pistol spray jets, due to put on some fan type but found this.
,the stuff you sterilise babies bottles with and leaving it for a day or so did the trick in getting rig of the smell etc.
