Bleeding Breaks?? HELP
Smart22186
Newbie
Feb 21, 2006
353
Peterborough, England
OK, so ive lost all fluid out of brakes due to a small problem with pads, any how, now im ttrying to re-fill the pipes etc...... can any one give some helpful tips on how i should go about doing this? do i need to bleed 2 whells at once or can i do it one at a time? :confused: :blink:
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
pads vs fluid?
eak! wot have you been doing.
pressure bleed or vacuum bleed them keeping resevoir filled the whole time, working your way around the bleed nipples front rear and clutch m/c if the whole system ran dry.
dutton
Rubber Bleed Tubes From Any Car Parts Shop Allow Single Handed Bleeding
I Suggest Bleeding The Two Rear Wheels Together
The Golf Has A Balancing Valve On The Rear Brake Pipes That Makes It Difficult To Bleed And Get A Hard Pedal Without Doing Them Together
