danscupra
cupradan
Jul 16, 2006
64
hi every one got abit of a problem right i have fitted a boost gauge and thats fine . ihave 6000k hid headlights and for some reason they keep blowin fuses just gone through 3 in ten mins any ideas why they might be blowing .
any help would be great thanks alot
dan
I need more information to be able to help.
Are the bulbs high wattage so are drawing too much current and blowing the fuse?
If it is one of these HID kits did you wire in separate relays to power the bulbs?
well i will get as much info as i can on them tomorow if thats ok the funny thing is i have had this hid kit working for ages ever since i put my boost gauge in its all gone abit wrong and started blowing fuses this is how i set the kit up .take old bulbs out where the old bulb was pluged into you put a positive and negative spade connector in there then that go's to the 12v packs thats about all you got to do .
thanks dan
