CalJames
Modification Addict
Jun 25, 2019
338
157
North Wales
So a few weeks ago my blend door actuator failed and after replacing all was good until recently, now I'm having issues with the passenger side only blowing hot air.
If I have the AC on full the drivers side is cold but the passenger is maximum heat.
The actuator isn't the problem as I can hear it working and it would cause both sides to be hot anyway. It's not a silica bag as mine doesn't have it, plus I was under the impression it'd be the other way round.
I've recalibrated the HVAC system and no difference.
Any help would be appreciated, thanks
Did you ever find a fix for this? Im currently stuck with the exact fault on my 2019 Cupra
You will need to get your air con recharged. About £70. My FR did the same. Took about an hour at the garage then I had the coldest aircon I have ever experienced haha.
Reactions: RWP
Same issue as I have. Not taken it in yet though so can't confirm a fix... Watching this space!
My post
