LeeroyBrown
Rite on!!!
May 7, 2005
359
Cornwall
Can any of you guys get hold of the door caps?? and different colour LED`s to go in them??? I would like some blue leds in both doors, as my mate has done it on his golf gti turbo and looks very good at nite.. Cheers all
Lee
flashbsd said:
just go to maplin and get some 1.5mm 12v LED's in blue ;)
yup i did mine for about £2
just buy some 3mm ultrabright blue LED's and some 470ohm resistors
then take your door lock surround apart and replace the red LED's with one new blue LED with a resistor in series
job done :)
just out of interest, and semi-related.
The doorcaps on the Leon are blanks - ie without doorpins. Does anyone know if you can get these blanks seperately (so i can remove my door pins as I have an import which has them - and make one with a blue LED in?)
the first time i took the door cards off, i must admit it was a bit daunting. i had done it to both my other previous cars but not the ibiza. i had no manual for the ibiza so was a bit harder!
but now i've taken them off several times and i can get a door card off in not much more than 60 seconds. its really very easy once youve done it once!
go on!.. give it a go! ;)
Lee
as said above, Maplins is your best bet as you can pick and choose colour/size etc.
Ive done this mod to both doors a while ago,see this thread
If you want an led in the passenger side your gonna have to remove door cards as you need to do a bit of cabling.
