Guys with Bluetooth, how do you tun the volume up for the phone and make it stay there?, when someone calls me I answer but have to turn the volume up from around 9 to something like 13, cant I make it stay at 13 automatically?
I had exactly the same problem. You need to press PROG, then the little button at the bottom for TLVOL (for telephone volume). Set it to 12 or 13 using the volume knob, then press TLVOL again.
It confused me for a while because if you don't press TLVOL again after setting the right volume, it'll reset itself to the previous setting; the second press saves the setting.
I didn't realise there was a setting for this, I just use the up/down buttons on the steering wheel as everyone I talk to is a different volume any way.
I have to adjust a bit for especially quiet/loud calls, but I found the default volume was consistently just too low. I find with my phone (Nokia 6300), it's about right if the volume is set to 12.
