Well if you have cruise control it is possible that you can have these options:
Please do keep in mind that not ALL of the later 1.4TSI have the 'fully loaded' option as of yet. However if you get the APR map done and the options are not available, when they do become available we can just update the software.
APR's EMCS is a truly modular system that allows for future enhancements and features to be added as they are developed without the need for additional hardware. EMCS makes the following advanced features possible:
Program Switching: Enables you to swap between two or more engine programs using the cruise control stalk. All cars have stock and standard chipped program versions available. Valet, race-gas, and other specialty programs are available for most models.
Fault Code Erase/Throttle Body Alignment (FCE/TBA) : Fault Code Erase allows you to erase and reset engine related trouble codes without having to use a specialty tool. Throttle Body Alignment allows you to manually perform throttle-body adaptation.
Security Lockout: Prevents unauthorized personnel from accessing EMCS functions. The user may select any 2 to 4 digit security code. The security code is entered using the cruise control buttons.
Anti-Theft You can render your car immobile to thieves, even if there is an attempt to start the car with your own key! For more information about Anti-Theft, click here.
Mike
