Couchwarrior
Hey all, I've just recently bought a 10 plate bocanegra to replace my old clio 182. I'm enjoying it so far, the gearbox is amazing and the engine is a little beauty. Feels pretty nippy but not as explosive as the clio was when the revs were up. Am interested in getting it remapped as I've read good things about it. Just wondering if anyone knows of or has had their car mapped in huddersfield or somewhere local. Don't really want to drive miles and miles for it.
Easiest option is to go to Awesome GTI in Manchester for an APR remap!
Thanks for the shout Beazy!
We are in Manchester, M44 5AH not too far away from Huddersfield!!
Mapping wise, we offer the APR mapping and on the stage 1 software you will see 200bhp and 223lb/ft all for £478.80 inc VAT
Depending on the ECU code it could be possible to have all the switchable options too if you have cruise control?
Give us a call on 0161 776 0777 opt 1 if you would like more info or to book in!
Mike
Mike
sorry to but in but you say switchable options??? like what?
I have cruise control :D
Well if you have cruise control it is possible that you can have these options:
Please do keep in mind that not ALL of the later 1.4TSI have the 'fully loaded' option as of yet. However if you get the APR map done and the options are not available, when they do become available we can just update the software.
APR's EMCS is a truly modular system that allows for future enhancements and features to be added as they are developed without the need for additional hardware. EMCS makes the following advanced features possible:
Program Switching: Enables you to swap between two or more engine programs using the cruise control stalk. All cars have stock and standard chipped program versions available. Valet, race-gas, and other specialty programs are available for most models.
Fault Code Erase/Throttle Body Alignment (FCE/TBA) : Fault Code Erase allows you to erase and reset engine related trouble codes without having to use a specialty tool. Throttle Body Alignment allows you to manually perform throttle-body adaptation.
Security Lockout: Prevents unauthorized personnel from accessing EMCS functions. The user may select any 2 to 4 digit security code. The security code is entered using the cruise control buttons.
Anti-Theft You can render your car immobile to thieves, even if there is an attempt to start the car with your own key! For more information about Anti-Theft, click here.
Mike
Mikes cliff notes:
1 - Stock Mode
2 - 95 Mode
3 - 98 Mode
4 - Valet Mode (Kills the accelerator pedal but the car can still be put into gear)
All switched through the cruise control stalk.
