Bonnet catch not working
munkimafia
63
Just filled up the windscreen washer and then my bonnet wont close!
Had it before, and got the garage to close it but its happened again.
Seems to catch on the first catch, but wont push the mechanism down properly to lock in place.
Pushing the mechanism down without the bonnet seems to work, and I can see the action that should occur, where by it pushes it down top the left,
Any one else had this problem? Know any solutions? Can provide photos if my appalling explanation doesn't make any sense!
Cheers as ever.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Extensive application of spray oil or motorcycle chain lube usually works, unless something has broken. Not WD-40, that just goes sticky itself after a while. The catch gets sprayed with water and crud from the road and needs lubrication every so often.
munkimafia
63
Thanks for the advice, alas it didnt work.
It seems like there is nothing pushing back from the bonnet side, to make the middle bit of the catch engage. I can see the first catch come across when closing the bonnet, but there is no push back to the second part that is required to close the second locking mechanism.
Will have to take it somewhere tomorrow and get it looked at.
Nothing wrong with the locking bit by the looks of thing though.
VERY frustrating
munkimafia
63
Fixed it!!!! The main, or first catch, had bent backwards towards the engine by about 15 degrees meaning it wasn't tall enough to grab the lock bar on the bonnet. Screwdriver to pull it forward seems to have done the trick. Not ideal though, cant help thinking a garage has dropped it too hard at some point. Thanks for the help though!
Dec 31, 2012
51
Hi, without sounding like a tool (not hard I know) whats the correct procedure to close the bonnet? Do you just drop it to close? I've tried pressing down on it but it doesn't lock shut? I really don't want to damage my paint or break the catch :(
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Drop a few inches or a sharp press from rest. Shouldn't need any more than that, at least mine never have.
dazjstuart
660
8
Aberdeen
I prefer dropping it from about a foot or so, don't really like pushing it from rest as I always think it might buckle the bonnet.
Dec 31, 2012
51
I've been told by countless body shops to NEVER press the bonnet when closing it. It should be dropped from a few inches.
I tried dropping it from around a foot but it didn't want to lock shut. Maybe I shouldn't admit it but I actually shut it down using me bum :lol: (I'm not overly portly so no dings were left on the bonnet anyway).
EDIT: Just tried it again and dropped it --> IT CLOSED! Maybe I just wasn't dropping it from high enough originally. I dunno I've just always closed my bonnets by pushing them down as I feel that's kinder on the car and it's paintwork. But I guess more likely to cause dents on newer modern cars.
