Hi there. I have a 2001
Seat Ibiza and am quite new to this site, I wont go into detail on visual mods. Basically I bought the car off of my brother about 2 months ago (he has been a member on this site) It has had a remap years ago and was pretty standard. My brother fitted an exhaust sytem, dump valve,intercooler, induction kit, bypassed n249. The car started to boost fine until 5th gear it would go into limp mode and faults - 17963 would come up and so would 17965. He then fitted a manual boost controller (he was told the remap could be too much for the car with the current remap causing overbost). The manual boost controller sorted it until I bought it and the
problem is back. We turned the boost down and it was still there, so I fitted an n75 valve - all seemed much better. I then turned up the boost and the faults are back - could the n75 have blown? I do feel like a saw a massive difference but don't know whats happened. Basically I am trying to find the
problem or I may need a remap. I was thinking about getting another new n75 and seeing what happens
I hope someone can
help. Thanks guys.
17963/P1555 - Boost Pressure Control: Upper Limit Exceeded
Possible Symptoms
Reduced power output
Limp mode
Possible Causes
Boost Pressure too High
Hoses/Pipes incorrect connected, disconnected, blocked or leaking
Charger Pressure Control defective
VNT (variable nozzle turbo): nozzles stuck
Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
Check Hoses/Pipes to/between Components
Check Solenoid Valve for Boost Pressure Control (N75)
Check / Clean / Replace Charge Pressure Control
Check / Clean mechanism for variable nozzles
17965/P1557/005463 - Charge Pressure Control: Positive Deviation
Possible Symptoms
Limp mode
Possible Causes
Possible Solutions
Got VCDS or access to it? (
www.ross-tech.com)
log block 115
disconnect n75 electrically and see what boost it does then... confirms what the actuators wound up to.
5psi is std
