Good point. Just saves twisting as they are a bit stiff to.No need to fit the other way round. The tops twist so you can change the direction.
Sent from my SM-A520F using Tapatalk
They may work as they just have to be 515nm to lift the boot lid and for a mk1 Octavia.HI, did anyone had fitted this struts, will work?
https://www.ebay.co.uk/itm/2X-SKODA...e=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649
Nice spot! have ordered so will find out if they work... am planning on trying to use the old boot struts to make up a DIY bonnet lift kit.......HI, did anyone had fitted this struts, will work?
https://www.ebay.co.uk/itm/2X-SKODA-OCTAVIA-MK1-HATCHBACK-1U2-1996-2010-TAILGATE-BOOT-GAS-STRUTS-1U6827550F/183159729871?ssPageName=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649
I've just fitted these and unfortunately they don't work too well, the boot pops up about half an inch then stops. Suppose I could try some silicone spray on the struts but I don't have any at the mo, may pop to screwfix on my way home from work tomorrow and report back. *fingers crossed*Nice spot! have ordered so will find out if they work... am planning on trying to use the old boot struts to make up a DIY bonnet lift kit.......
I had this issue and it was down to me not holding down the button on the key fob long enough...I've just fitted these and unfortunately they don't work too well, the boot pops up about half an inch then stops. Suppose I could try some silicone spray on the struts but I don't have any at the mo, may pop to screwfix on my way home from work tomorrow and report back. *fingers crossed*
I think its the struts, I hold the button and the boot lifts about 0.5 inch then stops, then I can lift the boot without touching the handle. Also I tried some silicone spray and it made no difference so I'm considering getting a couple of springs to fit to the struts to see if that'll help.I had this issue and it was down to me not holding down the button on the key fob long enough...
It feels like I'm holding the button down for about 1.5 seconds or so...
I'll try the button again, but it'll have to wait until the morning now as I'm busy getting drunk.![]()
is yours a 3 or a 5 dr?I had this issue and it was down to me not holding down the button on the key fob long enough...
Just double checking, no-one has found a solution yet for the ST? According to what I can find, tried reading the actual part details on mine with no joy, the ST standard struts are 589mm with a stroke of 167.5 and a capacity of 540nM. Would it be reasonable to assume its just the final figure, lifting capacity, that needs to vary to provide an unassisted lift?
well the cheap ones didn't work for me.... they open the lid about an inch, then it needs to be moved before it springs up..Can you report back on whether they work please?
I wonder if its because of the straight end couplers putting the strut at the wrong angle? the standard ones have an angle at the end that connects to the tailgate. Unfortunately the thread size on the cheap ones is different to the OE ones, so you can just swap them over...
oh well, its either in the bin, or get some helper springs...
