Borbet a 16's 7.5j
Rpayne89
I know this topic has been covered a lot of times (I've been searching for hours) but I haven't managed to really find any definitive answers.
I'm looking at buying some borbet as for my mk3 cupra 16s and 7.5j all round. The problem is the offset, all of which are 20.
I know the standard is 37 I believe?
And using various calculators this comes out to be an extra 3.6cm outward from the original wheels. Just want to know if these will actually fit without arch work?
And if any spacers will be required etc.
Rich
Aug 12, 2012
861
aylesbury
I have 16inch 9j alround no spacers was really low so I had my rear archs rolled still rubbed abit on the back but I didn't mindlol so yours should fit fine wanna swap two 7.5 for two of my 9j????
Rpayne89
How are the 7.5s on the front? I'm lowering mine on coilovers tomorrow as well you see... Worried about rubbing and they must definitely stick out quite a bit?
Also considering borbet bs.. Et is 35 on the front and 30 on the rear so would fit better?
Rpayne89
Really can't decide between the a's and the bs's
What do you think?
ndbrgr
THFC
Jul 21, 2008
1,023
Kent
Like i said 9j fit fine with 5mm spacers
Width is one thing, but offset is crucial.
This is my old cupra, 8s on the front ET32, 9s on the back ET27
Rpayne89
Your rr?
And where the hell did you find borbets with that offset? All seem to be 15s and 20s
ReC]<
I got Borbet A's 7.5j et20 on the front with no issues with 195x45x16 tyres. Just depends on how low you wanna go. Too low and i'm sure you'll get it scrubbing. You'll need spigot rings as well to suit (64-57.1mm IIRC)
