May 1, 2021
12
I'm going to replace the brake master cylinder and I'm wondering whether to bench bleed it first. I've done it before, on my daughter's Honda Civic, and I remember thinking it was a waste of time as the fluid dribbles out while you are fitting it to the car.
Anyone else done it?
It must make things a bit messy, if you are planning on using a pressure bleeder, why not just fit it dry and crack back open slightly each of the diagonal pipes and the clutch pipe at the start of the bleeding process.
