Hi i want to ask if the front brake pad in the cupra 290 is the same as in the 280? thank you.
orenhazan Active Member Jun 2, 2016 10 0 Oct 5, 2016 #1 Hi i want to ask if the front brake pad in the cupra 290 is the same as in the 280? thank you.
kazand Is powered by Medtronics Jun 6, 2010 4,138 73 Brum Oct 5, 2016 #2 orenhazan said: Hi i want to ask if the front brake pad in the cupra 290 is the same as in the 280? thank you. Click to expand... Afaik the brakes are identical.
AndrewJB Friend to SEAT UK & Cupra Racing Aug 16, 2007 11,210 484 Maranello Oct 5, 2016 #3 Yes. If you have the stock "Cupra" brakes they are the same. The Brembo's are also same.
Snah Active Member Jul 7, 2014 250 1 Netherlands Oct 5, 2016 #4 And stock they have Ferodo 2000 pads mounted.
orenhazan Active Member Jun 2, 2016 10 0 Oct 5, 2016 #5 AndrewJB said: Yes. If you have the stock "Cupra" brakes they are the same. The Brembo's are also same. Click to expand... thank you i have the stock brakes.
mardon Feel the DIFFerence Sep 22, 2008 2,599 2 A bean bag Oct 5, 2016 #6 What if you have the non "Cupra" ones on the 265?
