Ok guys first of all I already searched a lot on the board, on ETKA and on Brembo catalogue. I've a 1.4 44kw (hope to fit mk2 GTI 1.8 16v in future) and want to upgrade my brakes for street use and maybe some light track session. I would also like to fit ABS from a donor car but still try to see what parts I need to do the conversion. Anyway...
I think my actual brake setup is 239x10mm on floating caliper. Brake distances seems good since the car is very light but I would like to fit at last ventilated discs and don't want to add too much weight to unsprung masses.
This is the list of all mk2 brake setups I've found
239x10 (811 615 301 with 191 615 123 caliper)
1.0i
1.3i
1.4i
239x12 (321 615 301 with 1ho 615 124 A/C caliper)
1.4i
1.4i 16v
1.6i
1.8i
Diesel 1.9
Diesel 1.9 / SDI
Turbodiesel 1.9
239x20 (321 615 301 C with 1h0 615 124 A caliper) VENTED
1.4i 16v
1.6i
1.8i
Diesel 1.9
Diesel 1.9 / SDI
Turbodiesel 1.9 TDI
256x20 (6NO 615 301 D) VENTED
1.6i
1.8i 16v
2.0i
2.0i 16v GTI/Cupra/Cupra Sport
Turbodiesel 1.9 TDI
280x22 VENTED
I would exclude 280x22 since I still have 14" wheels, so I think my only choice would be 256x20mm (if it will fit) or just 239x20mm.
So
1)Anyone know if 256x20mm will fit 14" wheels with 33mm ET
2) 256mm discs, are the calipers floating or fixed? (if so, how many pistons)
3) 239mm discs, are the calipers floating or fixed? (if so, how many pistons)
4) A part from calipers, pads, discs what else I need to do the conversion?
thanks
Mario
1.0i
1.3i
1.4i
1.4i
1.4i 16v
1.6i
1.8i
Diesel 1.9
Diesel 1.9 / SDI
Turbodiesel 1.9
1.4i 16v
1.6i
1.8i
Diesel 1.9
Diesel 1.9 / SDI
Turbodiesel 1.9 TDI
1.6i
1.8i 16v
2.0i
Turbodiesel 1.9 TDI
280x22 VENTED
So
thanks
Mario
