HI all, hope you can help
Well things dont seem to have got any better after replacing the upper breather pipe. The general smoothness of the engine has gone and now feels a bit lumpy and somewhat sporadic.
I still get this 'hunting' (as a chap on here coined the phrase recently) where the revs raise slightly every 7 secs on idle and below 2500rpm in every gear. This momentary blip/jerk forward is really p@s5ing me off! Strangely enough, when I have the A/C on it doesn't seem to do it - almost like the engine has something else to concentrate on.
When replacing the upper breather pipe (which I thought was the cause) I did, as many of us have done, crack the harder plastic lower breather pipe. I've used thick masking tape on the split for now but do plan to get that changed soon. I dont think this is causing the problem though
In general, the power is still there and, as said, after 2500rpm things get a lot smoother
Any ideas? anybody had similar problem?
cheers guys/gals
cheers guys/gals
![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
