Leoncupra2800 Feb 13, 2024 4 0 Jun 13, 2024 #1 Does anyone know the part code / size for the pins on the brembo 4 pot callipers for the Leon Cupra?
SuperV8 Active Member May 30, 2019 1,982 1,038 Jun 13, 2024 #2 8J0698269 Only 1x side supplied in the OE set - and they are quite expensive for a couple pins and a spring clip! Reactions: Leoncupra2800
fuzzylogic Active Member May 22, 2021 22 16 Jun 13, 2024 #3 SuperV8 said: 8J0698269 Only 1x side supplied in the OE set - and they are quite expensive for a couple pins and a spring clip! Click to expand... Autodoc under £20 4 pins 2 spring clips. just enter OE part No in search box
SuperV8 Active Member May 30, 2019 1,982 1,038 Jun 13, 2024 #4 fuzzylogic said: Autodoc under £20 4 pins 2 spring clips. just enter OE part No in search box Click to expand... Sure - that's aftermarket versions. The OE - which I was referring to, is listed at £49 each side!
