Btcc jacking point cover
Rorza
247
Nuneaton
I went put to my car today and some jelous idiot has robbed my passenger side jacking point does any1 know where I could buy a knew front btcc jacking point cover for my fr tdi, I have emailed dave at Sere which I am waiting to here from but is there anywhere else that does them preferably with having to buy a whole passenger side skirt just for the front jacking point
Mar 25, 2008
660
They are available seperate. About £13 iirc, Dave will sort you out!
For what it's worth, they fall off themselfs sometimes.
Benzy
1,214
I had some one nick one of mine too buddy. I was not impressed, only had the car 2 days. I got mine from my local stealer as it.was the same price as sere but I would get it sooner. From what I remember it was only about £14
It comes in a pack, front and rear and just primed so Ull need to get it painted. If u take off ur drivers one before u call them, there's a number inside they need to ensure they send u the correct size.
Hope this helps mate
Sent from my HTC Wildfire using Tapatalk
May 20, 2010
564
skipton north yorkshire
Im on my second set now got first from sere and other from dealer both £13.its a bad design thay come off in floods and pot holes very easy.
Tip use abit of no nails or drill small holl and zip tie it
Rorza
247
Nuneaton
Thanks guys good to know there sold separately, so all I need is to buy some skoda black magic paint and spray a couple layers and couple of laquer and that's it
Cupra Jim
148
Coventry
I'm on my 5th set!
Gotta go buy the off side front tomorrow fom the stealers and gonna silicone these in!! and hide razor blades too, so it cuts their fingers off!!!
CovCupra
55
Midlands
You really on your 5th set Jim?? I think I'm on 3rd but only because the body shop broken set number 2...
I suppose the local chavs don't want mine with my colour choose...
robdf2
Yellow is the best
Feb 21, 2006
3,605
location , location
there are 2 part numbers for 2 different covers they vary slightly , the stealers have just fitted the wrong 1 to my car.
they are different by about 1/2 an inch and depending on which part number you need you either get 2 in a pack for £13 or only 1 for £13.
you will need to take the other cover off and look at the part number , it will either be starting with a p or a p1 iirc.
robdf2
Yellow is the best
Feb 21, 2006
3,605
location , location
you get 2 covers a side front and rear (you cant see rear)
part numbers
left side 1P1071625
right side 1P1071626
sets come primed and ready to paint
that might have been the case for your car but not the op.
there are 2 part numbers , depending on what side skirt you have fitted.
Mar 25, 2008
660
There are 2 skirts for the BTCC kit.
One is smooth and one has a large groove round the pointy bit.
ShazzaB
Jacking Point Covers
Hi I've had my car about 7months and just had my Jacking point Covers on the front both side's stole too.
Anyone any ideas where you can get them from?
May 20, 2010
564
You can get them from your local seat dealers think their about £13 a side primed. You might want to take therear jack cover off and get the part number because their are two different size covers on the btcc side skirt.
Oct 3, 2012
570
Cambridge
Just brought a candy white btcc and the drivers cover is missing so going to order my 1st set before even owning the car, definitely going to try and fix them on better!
Lee M
I've screwed mine on with stainless self tappers/washers. If you do it right you can't see the screw heads unless you get down on you knees and look.
Involves drilling the covers, the fixed part if the skirt, and jacking the car up.
