bumpers
G223
303
would they even fit? you know the front and rear tin bumper panels, they arent on the facelifted ones and as far as i know the front can be removed but the back cant, which is annoying as i slammed my back end into a high kerb and bent the side up :(
ibizaboy1.6
ive been told that the front bumper wont fit because the 'facelift' model has wider front wings than the other. but apparently the rear bumper will fit no probs. couldnt be too sure but i think my source is right!
Jun 17, 2007
1,032
Aberdeenshire
It can be done(i've done it) do a search it has been covered plenty of times. Back bumper bolts straight on minus the middle bolt.
Front requires a bit of work if you dont have the front splash gaurds, i also had to cut some of the pannel below the wing to get it to fit. as the front end of the facelift is wider so your source ibizaboy 1.6 is right. Some people have mentioned using some tin to take it out a bit for the bumper to fit.
But i had a spare facelift car to play with and had all the brackets and splash gaurds to play with.
hope this helps
