phillip877
78
malvern west midlands
Hi all yesterday I noticed alot of oil in my engine bay (Leon cupra r ) showed a mechanic today he advised me it will need a new cam cover gasket? Ok anyone else had this also how much are they for the part? And it would b a big big help if someone knew the part number I need as I wanna buy it from vw cheers ;)
Can't help you with the part number but i know the gasket for the VVT cam chain tensioner can leak, is the oil leak coming from the right hand side (stood looking under the bonnet) Above the engine / gearbox joint.
Apparently the leak from the VVT gasket is quite common and often thought to be rocker cover gasket.
Half moon gasket under vvt is the most common cause although rocker cover gasket do leak too. I do the vvt gaskets and rocker cover gaskets together to avoid future probs.
Ok ye sounds like it my mechanic looked at it earlier mite b worth doing both ;(
I have the same symptoms as above(leaking right hand side at the back above gearbox).
So is it just the one half moon gasket and rocker cover gasket i need? Anything else worth doing when i've got it all stripped down that far?
Speak to Dave at sere on here, cam chain gasket comes as two parts, the half moon and the gasket and costs approx 6.50, I've literally just bought one
is it worth repcling them? / is it hard to replace them?
mines been leaking for a while but im losing no oil and its not causing any problems so im inent to leave it unless its a cheap easy solution
I'm not losing oil as such, it's just getting the odd drip onto the manifold then burning off leaving a smell of burning oil, plus it looks filthy so want to get it tidied up. There's a how to guide on here somewhere, but it's a pretty simple job without the guide to be honest.
Will do mate, cheers. Are you only doing the cam chain gasket then or are you doing the rocker gasket an all? I just thought while it was coming off i may as well do it
HiiI changed rocker gasket and half moon near the rear of engine but now there is a little half moon under the vvt sensor that is blowing air and oil,do you know the part number or can you offer advice?thanks
