Andrewcupra TDI
Resident Desk Jockey
Apr 30, 2008
3,186
in the mountains ( Wales )
i have searched but to no avail,
i had my cambelt and pump and tensioners changed at 60,000
and read sumwhere about using vag com to set the timing back up, now i know this wasnt done,
it seems to run fine , perhaps slightly lumpier first thing, and seems to smoke abit lately approx 6000 miles later, but this could be because i now have a decat , when i put my foot down , i have a slight weap from the EGR valve could this be caked up and cause the smoke
im also hearing a noticable hiss noise on hard acceleration, asumed it was just the pd150 as other posts have mentioned , but am thinking could it be boost leaks - how do i check
cheers in advance
Timing set by Vagcom after a belt change, never heard this. From a mechanical point the timing is set by the vernier when you set it back up, though a belt change should not really disturb it, using a 6mm drill bit to lock the vernier in position before taking off the belt is how I have seen it done.
Hissing noise is probably down to the decat, you should hear mine when I floor it and even on idle it sound like a snake on steroids.
Glynn
if it's a PD you can check but not adjust with vag-com you will need to hunt for the relevant block - the range is -6 to 0 to +6 0 is spot on but up to +/- 6 is acceptable:)
