devilChris
does the camber kit exist?
I don't succeed in finding it.
can you insert some links? photo? and other ?
thanks
oooo thanks...
I hope it sends in Italy...
this kit go well with any coilover ?
it will stop you getting too much negative camber when you lower it, so it's a good idea
I think there are other options though - that was the first I found on google
I have looked for on google, but I have not found anything
but it comes me a doubt...
it is not possible to regulate the camber in the inferior trapeze (the arm of the wheel)? do kits exist?
The camber is adjustable on the front end of the LCR as it has the same swing arms as the S£ and 2WDTT. The ball joints are slotted into the swing arms allowing you to remove negative camber on lowering. The factory camber is -0.5 degrees. 034 do a camber kit combined with a strutt brace to give you a max of -1.8 degrees which is quite a bit. The Race spec LCR's run -3.5 Degrees on the front and -2.5 degrees on the rear.
the race spec leans dont run the same front hubs at all tho, theirs are fabricated items, totally different
I have contacted D2 MOTORSPORTs, but they don't make coilover with the regulation of camber.
in the model for the cupra r there is not the Top Mounts. strange.
I have also contacted Kw and they say that in the CLUBSPORTs for the leon cupra r there is the Top Mounts.. :think:
I must also buy some coilovers therefore I could buy the CLUBSPORTs...
:think::think::think::think::think::think:
If you bought the club sports you would be sorted for life, a very very good system that I would love to get my hands on.
This set up and corner weighted should be fantastic
ok... but for rear camber ???
kw have only front top mount....
ok... excuse me, I am Italian, my English sometimes has some hole.
for rear...
http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=260301CHAS&product=FMAUTB2
